Create a UUID as a parameter that persists through the whole workbench
oliver.morris
Forum|alt.badge.img+13
Morning,
I would like to create a UUID in my workbench as a parameter and call it at various points through my workbench. The issue I have is that currently it keeps generating me a new UUID every time I call it. I am using the @UUID() function.
Is there a way to populate the parameter once and persist it thoughout the workbench so I can use it in filenames, database table names etc.
Many Thanks,
Oliver
Best answer by david_r
I use this pattern with a private scripted parameter quite a lot:
Code:
import uuid
return str(uuid.uuid4())
It's then easy to reference this parameter value wherever you need it in the workspace.
  • July 10, 2018
Code:
import uuid
oliver.morris
  • July 10, 2018
@david_r
Thank you this works perfectly for my needs.
