create a tin
  • Mar 26, 2026 1:24 PM UTC
  • 6 replies
  • 109 views
mitra
Forum|alt.badge.img+4
All I want to do is create a TIN from a point CSV. I have used the TINGenerator transformer, but the TIN that is created does not have any elevation. The geometry is 3D in the Inspector, but it does not show any height information. If I create a TIN in ArcGIS, it has the correct elevation. I will also post my workflow. Can anyone help me?
s.jager
Forum|alt.badge.img+27
  • Mar 26, 2026 2:25 PM UTC
I’m sure somebody can help you, but without a wee bit more information that is difficult, and mostly guesswork.
I suspect your csv-features do not have geometry, since you are not creating it in your screenshot - and if the grens_totaal_dissolve features have no elevations, your TN won’t either. But without knowing a bit more I can’t say for sure.
max_h
Forum|alt.badge.img+39
  • Mar 26, 2026 2:45 PM UTC
Instead of a csv reader, try using a ‘Point Cloud XYZ’-reader and activate feature caching to check the geometry.
An excerpt of your csv would help plenty otherwise
mitra
  • Mar 26, 2026 4:39 PM UTC
​@s.jager
I already have a CSV file containing X, Y, and Z (elevation) values. I’ve attached a screenshot of the CSV file. The grens_totaal_dissolve represents the boundary of the area where I want to create a TIN. All the point data are within this boundary.
I also tried creating a TIN without using this boundary, but the resulting TIN still does not display the elevations.
chriswilson
Forum|alt.badge.img+29
  • Mar 27, 2026 1:08 AM UTC
You could try a VertexCreator to create the z values for your points from the elevation field of your CSV, or set that field to be the z-coordinate field in the reader.  This does depend as others have mentioned on your CSV having a field with elevation in it.
itsmatt
Forum|alt.badge.img+48
  • Mar 27, 2026 2:05 AM UTC
1 - Confirm all your input features are in 3D and have non 0 for Z. Use the Record Information window to be sure. In my screenshot It show the data are 2D.
  1. Verify that all input features has the same coordinate system
  2. Verify the output from the TINGenerator is 3D. View it in 3D mode and check the Min and Max extents in the Geometry of the TIN. Verify the maxz coordinate is not 0
  3. Check your write output format is set to a format that supports 3D. Make sure that the writer isn’t configured to be 2D only. You can use FME to Read the data back in via the FME Data Inspector to be sure they are 3D after writing out.
s.jager
  • Mar 27, 2026 9:03 AM UTC
Yes, but if you read that csv-file in with the csv reader, it won’t create geometry. Attach an Inspector to the reader, and you’ll find that you’ll get features with three attributes, but no geometry. The TIN Generator relies on the incoming features having geometry with x, y and z coordinates, and yours do not as it is right now in your screenshot.
The VertexCreator, like Chris suggested, is probably the quickest solution to fix that. There are other options as well, by the way. So add a VertexCreator after the first Tester, or maybe after the AttributeManager (I don’t know what you do in those), and then you don’t need the 3DForcer anymore.
