Create a 3D vector with Vertex Creator
  • Feb 25, 2026 9:20 AM UTC
  • 60 views
giuseppecfgeo
Forum|alt.badge.img+5
Hi everyone,
In FME 2023, does anyone know the correct way to create a 3D vector starting from a list of 3D coordinates referring to two different moments in time?
In the past, it was possible to connect two Vertex Creator transformers to generate a 3D vector by linking two 3D points. However, it seems that this is no longer possible in the same way.
Any suggestions or alternative solutions?
itsmatt
Forum|alt.badge.img+48
  • Feb 25, 2026 4:45 PM UTC
Hmm, what you're doing sounds correct. Double check the settings of the VertexCreator. There are several options. One is Add Point which is what you're looking for.
I think the default is Replace With Point so maybe you're just using the default?
If you're already using Add Point then what is the behaviour you're seeing?
