Count number of characters in multiple fields
  • Apr 18, 2024 12:53 PM UTC
  • 414 views
timotheebecker
Forum|alt.badge.img+3
Hey.
I need to count the number of characters in all text fields of my dataset.
Any simple way to do this to avoid using multiple StringLengthCalculator ?
joepk
Forum|alt.badge.img+22
  • Apr 18, 2024 1:27 PM UTC
Hi, you can use @StringLength(<string>) in e.g. AttributeManagers, AttributeCreators, ExpressionEvaluators etc. Could that be of help to you?ย
You could use a BulkAttributeRenamer to create copies (Mode: Keep Original Attributes) of your attributes with a prefix, then use an AttributeManager to set all attributes with your prefix to the value โ€œ@Evaluate(@StringLength(@CurrentAttribute()))โ€
Or directly overwrite your attributes with their lengths using an ExpressionEvaluator with this expression: @StringLength(@CurrentAttribute())
nielsgerrits
Forum|alt.badge.img+67
Or ue the AttributeExploder to create a feature for every attribute and send them through the StringLengthCalculator.
jkr_wrk
Forum|alt.badge.img+37
  • Apr 18, 2024 2:23 PM UTC
If you need to know what length the fields have, because you need to create a database for the features you should use a schemascanner:
The Schema feature will contain a list of all Attributes with the max length of the attribute:
If you need to validate the length of the attributes because you need to know if it fits in the database you could use a AttributeValidator:
ย
hkingsbury
Forum|alt.badge.img+73
  • Apr 18, 2024 7:47 PM UTC
I like these problems, because there are so many ways it can be solved!! Yet another approach would be using a python caller with the input function being (leave the others as default)
    def input(self, feature: fmeobjects.FMEFeature):
for f in feature.getAllAttributeNames():
if f == '_count':
pass
else:
attr = feature.getAttribute(f)
if isinstance(attr, str):
feature.setAttribute(f, len(attr))
self.pyoutput(feature)
This will replace the attribute value with the length of it. You can also add logic to only do certain types, or ignore certain attributes (in this case iโ€™m ignoring โ€˜countโ€™ and only getting the length of strs). Using a couple of bulk renamers and an aggregator you can add the lengths back onto the original feature
ย
ย
