correct settings for feature reader from a list?
  • Apr 20, 2020 4:38 PM UTC
  • 119 views
alfons
Forum|alt.badge.img+7
Good evening,
I have two shapefiles, which I want to merge with each other and then continue working with the partial results. One shapefile contains the boundaries of the municipalities and the other shapefile contains the BoundaryBoxes of the LAS tiles. Since the amount of data is too large, I want to process the data community by community.
The tiles marked in blue contain the names and paths of the individual LAS tiles in an attribute [ID].
In my Workbench I perform a spatial selection using the SpatialRelator. For this I connected the shapefile with the information of the LAS tiles to the supplier port and connected the community boundaries to the requester port. .
As a result, I get a list of all elements that contain the community (like the tiles marked blue in the first picture). To check if the selection is correct, I exploded the list with the Listexploder. The result is correct and so far everything is clear.
Next, I want to read the 22 selected tiles, which are stored in the [ID] column with the path, from the directory of all tiles and process them for this municipality. I would do this with the FeatureReader, but I am not sure how to set up the settings so that only these 22 tiles are read in and are available for further processing. All my attempts with various settings either didn't bring any data for further processing or all data in the (total) data directory were read in. My question now is, how do I configure FeatureReader to read only the elements of my "_relationships" list, their path and name in the [ID] attribute? Maybe there is a more efficient way?
Thanks a lot in advance from a FME newbie.
PS: Once I have solved this problem, I wonder how I can do this automatically on a community basis (community by community). At the moment I have defined the one community directly with a tester.
erik_jan
Forum|alt.badge.img+26
  • Apr 20, 2020 4:47 PM UTC
After exploding the list, you can use the ID in the FeatureReader like this:
Then use the Generic output port, which should get you the set of Lidar features.
Another option, instead of exploding the list, would be using the ListConcatenator to create a comma separated string of files from _relationships{0}.ID.
Then you can pass the whole set of files to the FeatureReader in one go, using the ID attribute.
Hope this helps.
alfons
  • Apr 20, 2020 5:45 PM UTC
Hi Jan Erik,
thanks a lot for your two suggestions. Both of them are working perfectly. It was so simple, but I always thought that I had to reference to the list. Thanks a lot. 8-)
Forum|alt.badge.img+54
  • Apr 20, 2020 5:55 PM UTC
On your second point, you could consider creating a parent workspace with a workspace runner to process community by community
