correct connection errors between two polygons
  • February 26, 2015
  • 27 views
We need a way to correct connection errors between two polygons , up to a Certain distance in meters and if pass this distance to insert a point to manually check.
Example 01 - Connection error corrected between two polygons with distance up to 2 meters
Example 02 - connection error between two polygons with distance of 6 meters ,above the 2 meters insert a point
Att
Bruno Lima
Best answer by takashi
Hi Bruno,
I would use the Snapper to correct the 1st situation, and then use the TopologyBuilder for the 2nd.
Takashi
  • February 26, 2015
Hi Bruno,
Takashi
