Copy Down attribute in ordered table until another attribute changes
daveapegg
Forum|alt.badge.img+4
Hi guys, this seems like it should be a simple thing to do but I can't find a way to do it. I have a point feature class that needs to be turned into polygons. The first point for each polygon has a "Start" attribute but the rest are missing.
The table is ordered so that the points are sequential so I want to use a GroupID from the first point and apply it to the all the points until the next feature that is a "Start".
I've tried a line builder to GroupBy "Start" and it will draw the line but won't include the Start point.
I'm using FME 2020.1
Cheers, Dave.
hkingsbury
Forum|alt.badge.img+55
  • February 25, 2021
have a look at this.....
daveapegg
  • February 25, 2021
Thanks very much Hamish, this has helped a lot!
