Coordinates Error converting DGN to DWG
  • Mar 19, 2020 12:53 PM UTC
  • 82 views
Hey there,
I'm trying to convert Microstation DGN files into DWG to use them in Revit. Unfortunately the coordinates change a lot while doing so (see attached) and I can't make out why? Anyone got any idea why that is?
I tried auto selected coordinate system as well as manually selected.
DGN
DWG
daraghatsafe
Hi @hardyneuer, could you provide your workspace and the DGN file that you are working with?
