Coordinate value formatting in XML output
  • Jun 2, 2022 3:05 PM UTC
  • 110 views
I am using FME 2021.2 with a PostGIS reader and an XML Templater and XML Formatter to write an XML output file. This works fine, but the coordinate X/Y output appears in scientific notation as below:
 <Vertex>
  <X>2.010340655257836E6</X>
  <Y>6.7378739141772166E6</Y>
 </Vertex>
I have tried all kinds of different things, however I can't get FME to format the output they way I want it like below:
    <Vertex>
      <X>2010340.655257836</X>
      <Y>6737873.914177217</Y>
    </Vertex>
This code fragment in the XML Templater works:
<Vertex>
 <X>{geom:get-x-coord()}</X>
 <Y>{geom:get-y-coord()}</Y>
</Vertex>
This does not:
<Vertex>
 let $l := geom:get-x-coord()
 let $r := @Format(%.2f,$l)
 return $r
</Vertex>
I can't figure out how to pass the X value above into the format function, or find another workaround.
Best answer by debbiatsafe
Hi @sdfghjk7777​
Please try the following in the XMLTemplater
<Vertex>
    <X>{xs:decimal(geom:get-x-coord())}</X>
    <Y>{xs:decimal(geom:get-y-coord())}</Y>
</Vertex>
This returns decimal notation coordinates in my tests. I hope this information helps.
debbiatsafe
Forum|alt.badge.img+24
  • Jun 2, 2022 9:56 PM UTC
Hi @sdfghjk7777​
<Vertex>
</Vertex>
Thank you, that solved my problem. You guys are fantastic. I am just not familiar enough with all the xsd syntactical elements in combination with using the XML Templater.
