Converting OSM to DGN with the same colors ????
  • Jun 7, 2021 5:52 PM UTC
  • 86 views
gogopotter90
Forum|alt.badge.img+14
Could I convert open street map to dgn file with the same color as maps .
I would like to extract only one polygon from OSM to dgn file with the same color as map .
How could I achieve that ?
Fme 2018
Thanks in advance
caracadrian
Forum|alt.badge.img+23
  • Jun 8, 2021 4:29 AM UTC
OSM in a collection of vectors with styles assigned on the browser side.
You can extract features from OSM and set color manually via DGNStyler.
gogopotter90
  • Jun 8, 2021 8:18 AM UTC
Is it possible to extract the color in any attribute from maps then use the color later again in dgn writer .
Bcs I have different polygons and each has his specified colors.,river ,streets,bridges ,etc .
I want to do it automatically ,if there is a method ,I will be thankful
caracadrian
  • Jun 8, 2021 9:05 AM UTC
I suppose there are repositories with styles for different views of OSM.
If your polygons already have color you can translate fme_color (use AttributeExposer) to the color system used in DGN files via DGNStyler.
