Converting 360 Image to e57 data format?
  • Jun 10, 2020 4:14 PM UTC
  • 5 replies
  • 474 views
Hye Everyone, Im still newbie in e57 format. May i know whether i can convert my 360 image in JPEG to e57 data format? Thanks and Sorry.
danilo_fme
Forum|alt.badge.img+58
  • Jun 11, 2020 1:01 PM UTC
Hi @mjbaz
If you want just to convert JPG to e57:
1) FME Desktop Workbench -> File -> Generate Workspace:
2) The mapping Reader -> Writer was created:
Thanks in Advance,
Danilo
  • Jun 12, 2020 5:12 AM UTC
Hi @mjbaz
Thanks in Advance,
Danilo
Thanks for your respond. I already tried your method and successfully converted to e57. However that e57 file doesn't have metadata such as XYZ. Any idea for this issue? Thanks in advance.
danilo_fme
  • Jun 12, 2020 10:26 AM UTC
Hi @mjbaz
I include the transformer CoordinateExtractor ( jus a test ) and after in included on the Writer file:
The x and y information on the Writer:
Is that similar your question?
Thanks in Advance,
Danilo
  • Jun 12, 2020 12:22 PM UTC
Hi @mjbaz
Thanks in Advance,
Danilo
Sorry for my confusing question above. Ok the situation right now i have 2 datasets, 1 is 360 panoimage and 2 is metadata of that 360 image contains xyz information. So the idea is to convert these 2 datasets to e57 file that carry xyz information from metadata. FYI, 360 image and metadata have same naming. Is it possible to do this? Thanks for your help.
danilo_fme
  • Jun 12, 2020 12:25 PM UTC
OK. Could you share a sample your Readers or FMWT - template?
