convert .txt to .csv
parashari
Hi. Working on FME2015 32-bit. I have a text file (.text) which contains schema in its first row. I want it to convert to csv file. Each entity is enlosed in inverted commas and all the attributes are seperated by a comma. Is there any possible way to convert a text file to a csv file? PFA- image (txt2csv.jpeg)
I have tried using AttributeSplitter using expose elements but it it showed only one attribute at at time. Thanks :)
  • May 21, 2015
Looks like the text is written in the CSV format already.
I don't think any conversion is necessary...
What kind of transforming do you need?
parashari
  • May 21, 2015
I just wanted to know how can we convert a text file to a csv file (if we can) when the values are seperated by a comma,. Since I come across many issues like the conversion of text file to csv, xlsx, shp etc, so I just wanted to know about it. Consider the image as an example.
  • May 21, 2015
CSV is "Comma Separated Values".
If the values in the text have been seperated by commas, that is the CSV.
Am I missing something?
parashari
  • May 21, 2015
Thank you so much Takashi :) Dump question it was :P
gio
Forum|alt.badge.img+15
  • May 21, 2015
...lol
pratap
Forum|alt.badge.img+12
  • May 21, 2015
Text file to csv or xlsx is easy in Excel itself
