convert .txt to .csv
parashari
Hi. Working on FME2015 32-bit. I have a text file (.text) which contains schema in its first row. I want it to convert to csv file. Each entity is enlosed in inverted commas and all the attributes are seperated by a comma. Is there any possible way to convert a text file to a csv file? PFA- image (txt2csv.jpeg)
I have tried using AttributeSplitter using expose elements but it it showed only one attribute at at time. Thanks :)
Looks like the text is written in the CSV format already.
I don't think any conversion is necessary...
What kind of transforming do you need?
parashari
I just wanted to know how can we convert a text file to a csv file (if we can) when the values are seperated by a comma,. Since I come across many issues like the conversion of text file to csv, xlsx, shp etc, so I just wanted to know about it. Consider the image as an example.
CSV is "Comma Separated Values".
If the values in the text have been seperated by commas, that is the CSV.
Am I missing something?
parashari
Thank you so much Takashi :) Dump question it was :P
gio
Forum|alt.badge.img+15
  • May 21, 2015
...lol
pratap
Forum|alt.badge.img+12
  • May 21, 2015
Text file to csv or xlsx is easy in Excel itself
