Convert Polygon (Area) to Surface
From my reader I get an area feature (determined by the 'GeometryFilter'), but for my writer I need a Surface Feature. How do I convert an Are to a Surface?
Thanks a lot!
Michel
gio
Forum|alt.badge.img+15
  • April 17, 2014
Is your object 2d or 3d.
If its 2d u can extract some vertices (preferably cornernodes) and us a surfacemodeller. If that is what u are looking for thats is.
Gio
  • April 17, 2014
Hi Michel, probably the FaceReplacer transformer is what you are looking for.
Takashi
  • February 22, 2021
gio wrote:
Gio
Hi gio,
If my object is 3D, then how can I convert the Area to Surface?
Regards, Fang
daraghatsafe
fang wrote:
Hi gio,
Regards, Fang
Hi @fang​ have you tried using the 2DForcer transformer to remove any z elevation?
  • February 23, 2021
fang wrote:
Hi gio,
Regards, Fang
Hi@daraghbroderick, ​my Area is 3D and I need z elevation, you could see it from my uploaded pictures. The polygon is made up of four boundary lines including an Arc. My ultimate goal is to build solids and it seems that only faces can build up solids, but I haven't find a solution to build faces in 3d. Do you know how to do these? Thanks a lot.
2021022308422620210223084216Best, Fang
Maybe this answer is not directly related to this specific question but still:
I have an ifmeMultiarea (polygon parts) which I wnat to turn into a surface. Since FaceReplacer is time consuming and error prone because of generating allt the triangles. My workaround is saving the MultiArea as an obj and reimporting it, now it is a Surface :)
