Convert lat/lon in OSGB36 to lat/lon in WG84
  • January 28, 2015
  • 101 views
Hi all,
I have a csv which contains tree columns: ID, latitude and longitude. These lat/lon values are projected in OSGB36. My questions is:
How can I convert these latitudes and longitudes in OSGB36 into latitudes and longitudes in WG84?
I would appreciate any help.
Best answer by fmelizard
Read the attributes and use the AttributeReprojector, or create features and reproject them (if necessary)
fmelizard
Forum|alt.badge.img+22
  • January 28, 2015
  • January 28, 2015
Hi ETLS-Itay,
Thanks for your reply. It seemed to work using the next parameters:
Where my East field contains the Longitudes and my North the Latitudes. In addition, intead of using the OSGB36 and WGS84 projections as such, it's better to use their SRIDs. I found this after quite a lot of tests.
