Convert DWG with no projection to BNG and Shapefile
  • Jun 29, 2022 11:03 AM UTC
  • 209 views
I have a dwg in CAD, it doesn't have a projection, I need to convert this to a shapefile, how can I add the British National Grid and move the drawing to the correct co-ordinates?
muzhnasto
Forum|alt.badge.img+12
  • Jul 1, 2022 1:29 PM UTC
Hi, maybe first in shp and then in Qgis move your hands?
jovitaatsafe
Forum|alt.badge.img+11
Hi @saqibamin​
Does your DWG file currently have a known coordinate system? If so, you can use the CoordinateSystemSetter. If not, you will need to move this file into a known location through the LocalCoordinateSystemSetter before reprojecting to the British National Grid.
If you do not have known points in the file linking 0,0 on the file to a known point on the Earth's surface, you may need to do some guesswork with Google Maps. Or you could try ArcGIS where I believe there's a tool you can adjust your dwg to the correct location against a basemap.
