Connect vertices with line
  • Oct 11, 2018 10:45 AM UTC
  • 56 views
Hy
I nee to connect opposite vertices within certain distance tolerance and then calculate the middle point off the connected line
Thx
Francesco
mark2atsafe
Forum|alt.badge.img+59
The Snapper - or AnchoredSnapper - transformer will help you connect lines within a certain tolerance.
NeighborFinder is also worth looking at as it logs the distance and the angle to the neighbour.
