Concatenate parts of lists
  • May 3, 2022 7:57 AM UTC
  • 208 views
deanhowell
Forum|alt.badge.img+24
I have run some stats on a dataset where features fall into a specific polygon and have the count and the category.
I now need a list that I can bring together in a single concatenated value that is {count1, cat1, count2, cat2, count3, cat3}
The problem is that the number of the categories varies from polygon to polygon.
The approach so far is statistics calculator => list builder => list concatenator (using category) => list concatenator (using count) which gives me two lists, comma separated but need to being them together.
imagewith the result
imageDoes anyone have any suggestions on how to bring together?
Best answer by geomancer
My thoughts exactly.
Severity
Forum|alt.badge.img+54
  • May 3, 2022 8:12 AM UTC
Is there a reason you can't join the severity and the count prior to building the list?
geomancer
Forum|alt.badge.img+71
  • May 3, 2022 8:20 AM UTC
Severity
deanhowell
  • May 3, 2022 8:33 AM UTC
Thanks for helping me to open my eyes​
deanhowell
  • May 4, 2022 3:05 AM UTC
Just an update as the solution worked as expected but just wanted to share a couple of changes. I had to add a ListDuplicateRemover to ensure the entries were unique. I also needed to add a FeatureMerger as I had lots of stats to merge together. Thanks @geomancer​ amd @ebygomm​ as sometimes you can't see the obvious.
