Compare multiple fields after a spatial filter
pi_hellz
I'm looking to compare the difference between multiple columns that is resulting from a feature merger.
example :
IDTypeYearCityStreet_type_year_city_street121999QCDuke21999MTLDuke232001MTLKing12002MTLThomas
I need to identify each difference and export them to a report. The problem I have is that another validation of the same benchmark might have too 8 columns to compared.
Thanks for your help
Forum|alt.badge.img+54
  • July 27, 2017
Are you not better to skip the featuremerge and use a matcher or a change detector to identify differences?
pi_hellz
  • July 27, 2017
Sorry I mean a spatial filter not a featureMerger. I tried the change and update dectetor and I did not get the expected result.
I was more looking for a python loop ?
jneujens
If this is just about identifying the features where the attributes are not equal to each other, you should try to use the matcher (or multiple matcher in a sequence).
Notice that the matcher uses regex to compare attributes.When you compare multiple attributes at the same time, they are all concatenated and compared. So, if only 1 of many attributes are different, it will not match.
