compare attributes of two different tables
  • November 21, 2013
  • 326 views
vki
Forum|alt.badge.img+8
I have two tables that are related through two attributes (Attribute A of table 1 and Attribute B of table 2). Now I would like set a new ID-Attribute (primary key) in table 1 and use this ID as the foreign key in table 2.
That means that I have to compare the attributes of the two tables and if attribute A of table 1 equals attribute B of table 2 then I write the ID-attribute of table 1 as FK to table 2.
I looked through the transformers but I couldn't find one where I was able two compare attributes of two different tables. But there sure is one...?!
Thanks in advance
Vera
fmelizard
Forum|alt.badge.img+22
  • November 21, 2013
The FeatureMerger can be used with multi keys to join on.
But in this case a single key (A and B), would do the job.
Itay
vki
  • November 22, 2013
Thanks Itay.
It took me some time to sort things out, but finally I got it working.
Vera
