I have duplicate line segments with same unique ID but different lengths. I would like to filter out the shorter line and keep the longer line for further transformation.
Compare and filter out line with shorter length
Best answer by jdh
Calculate the length, sort your features by length and then use a sampler (First 1 feature), grouped on the Unique ID attribute. The longest lines will be from the sampled port, and the shorter duplicate lines will be sent through the unsampled port.
Alternately use a DuplicateRemover in place of the Sampler.
<strong>This post is closed to further activity.</strong><br />
It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br />
If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br />
