Combining multiple links /lines and summary an attribute.
  • Feb 5, 2025 10:54 AM UTC
  • 51 views
clowncutie
Forum|alt.badge.img+7
Hi, I have multiple lines / links that each have attribute  per feuture
ID  Vehicle Load
1   0
2  300
3  250
In this case I would like all of them to create a single line with the total load, so new ID:4 and load:550. not keep the old ones.
This is the easier part however ther are intersections as well. Some times very complex ones:
Preferably this should be 2 lines with one node in the center. Maybe 2 parallell ones for the left lower part.
I have done similar before with snapper and topologybuilder but would appreciate help. I used segment snapper.
My workspace
ali-safe
Forum|alt.badge.img+24
  • Feb 11, 2025 1:16 AM UTC
Hi, ​@clowncutie.
Thanks for posting your question. Wonder if I could request a sample workspace from you? Going to try and see if it may be possible.
Thanks
