Combine single character text features to create words (longer strings)
  • Oct 23, 2023 4:01 PM UTC
  • 132 views
0xbox0
Forum|alt.badge.img+5
I'm trying to read PDFs and it looks like each character of each word is represented as individual features. Each PDF has thousands of these text features that I need to combine to make words. I'm stumped as to how to string these single character text features together to create words.
I have attached an example below.
Any help would be appreciated. Thanks in advance.
Best answer by david_r
Unfortunately, changing the Spatial Text parameter didn't help in my case and I haven't gotten around to trying to figure out the Python.  Thanks tho for the suggestion.  I'll give it try again later on.
Cheers
As a starting point, here's sample code for the PythonCaller that will output a feature for each individual text block that is found within a PDF, as specified in the attribute "pdf_filename":
import fmeobjects
from pdfminer.high_level import extract_pages
from pdfminer.layout import LTTextBoxHorizontal, LAParams
class ExtractPdfTextBlocks(object):
    def __init__(self):
        # LAParams documentation can be found here:
        # https://pdfminersix.readthedocs.io/en/latest/reference/composable.html
        self.params = LAParams(line_margin=0,
                               detect_vertical=False,
                               boxes_flow=None,
                               all_texts=False)
    def input(self, feature):
        pdf_filename = feature.getAttribute('pdf_filename')
        for page_layout in extract_pages(pdf_filename, laparams=self.params):
            for element in page_layout:
                if isinstance(element, LTTextBoxHorizontal):
                    text_string = str(element.get_text()).strip()
                    text_x_pos = element.x0
                    text_y_pos = element.y0
                    text_bbox = element.bbox
                    # Create a new feature for each text block found
                    new_feature = feature.clone()
                    new_feature.setAttribute('page_number', page_layout.pageid)
                    new_feature.setAttribute('text_x_pos', text_x_pos)
                    new_feature.setAttribute('text_y_pos', text_y_pos)
                    new_feature.setAttribute('text_bbox', str(text_bbox))
                    new_feature.setAttribute('text_string', text_string)
                    self.pyoutput(new_feature)
    def close(self):
        pass
You'll want to expose the following attributes in the PythonCaller:
  • text_x_pos
  • text_y_pos
  • text_string
  • text_bbox
  • page_number
Sample output:
imageTo install pdfminer.six, open a command prompt as local admin in the FME installation folder:
fme python -m pip install pdfminer.six
See also: https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/Installing-Python-Packages.htm
Documentation for pdfminer.six: https://pdfminersix.readthedocs.io/en/latest/index.html
  • Oct 23, 2023 4:14 PM UTC
In the reader parameters, make sure the spatial text is read in as one feature per (text) block:
imageIn theory, that should fix it, but my experience has been mixed, in particular with narrow fonts or particular page sizes. For some documents, the only reliable results I got was from this Python module, which is really exceptionally good at locating text blocks: https://pdfminersix.readthedocs.io/en/latest/ For maximum integration into your workspace, you'll have to implement it in a PythonCaller, but it's apparently also possible to use it on the command line.
0xbox0
  • Oct 30, 2023 3:32 PM UTC
Cheers
  • Oct 30, 2023 4:20 PM UTC
Cheers
import fmeobjects
    def __init__(self):
                               boxes_flow=None,
                               all_texts=False)
    def close(self):
        pass
  • text_x_pos
  • text_y_pos
  • text_string
  • text_bbox
  • page_number
Sample output:
