Column names to several different rows
  • Nov 6, 2024 2:28 PM UTC
  • 100 views
a_ericsson
Forum|alt.badge.img+4
Hey!
I’m trying to do something that in my mind is very tricky, mainly because I don’t know how to do this. I have a table with bird “routes”. For some reason, each bird species is in a separate column, with a value for the number of individuals in that column. It can look something like this:
In row 2, at one given location, 1 “Stare” and 1 “Grönfink” have been spotted. There are around 190 columns, making this table a bit odd to work with. To work with this data in a different project, I would like the table structured differently. What i would like as an output is a seperate row for each observation, with number of individuals as a seperate column. So, in this case, row 2 would be 2 rows, one for the “Stare”-observation and one for the “Grönfink”-observation. Basically, turning the column names into attribute values.
Does anyone on this forum have any experience from this? Any help would be greatly appreciated!
Cheers!
/Alex
Forum|alt.badge.img+54
  • Nov 6, 2024 2:46 PM UTC
The attributeexploder will do this. I would map your 0 values to missing with a nullattributemapper before doing the exploding
a_ericsson
  • Nov 6, 2024 3:11 PM UTC
Thank you very much! :)
