Cloner, duplication issues after 10,000 rows
  • Nov 4, 2019 3:42 PM UTC
  • 52 views
rsupple
My issue is, my 'source' dataset (6,600 rows) needs to clone each single row 54 times,
example - Row '2' is cloned 54 times so the 'output' has 54 identical rows of '2' (to then later be transposed..etc..);
I have noticed once the completed 'Output' dataset reaches 10,000 rows it starts again from the top (row 2 of source again), so row 2 has 54 correct clones and then it repeats again at 10,002, 20,002, 30,002 etc......
The issue: Original row 2 repeated again at row 10,002
Simplified set-up:
Hope someone can help?
regards,
Richard
fmelizard
Forum|alt.badge.img+22
  • Nov 4, 2019 7:37 PM UTC
Hi @rsupple I'm unable to reproduce your problem. Which build of FME are you using? If you still see this behavior with the latest beta then please send us details of your case.
rsupple
  • Nov 5, 2019 7:12 AM UTC
Hi Dan,
I believe I have the latest version, 2019.0.1.0
chrisatsafe
Hi Dan,
Hi @rsupple,
We just released the official 2019.2 yesterday, would you be able to try running this workspace in the latest build? Note: you may need to upgrade some transformers for the fixes to take effect - similarly, you can also upgrade the reader/s and writers if applicable.
You can download it directly from the FME Downloads page. As Dan suggested, if the issue still exists in the latest build, can you please send us the workspace so we via the Report a problem webform so we can further investigate.
Hope that helps.
rsupple
  • Nov 12, 2019 11:50 AM UTC
Hi Dan,
Hi Chris,
I'll speak to the team who updates our systems applications and request the update and let you know if this has solved the issue for me.
thank you,
