Clipping raster files accuracy
  • February 19, 2019
  • 7 replies
  • 74 views
Hello,
I have polygon from postGIS DB and raster file. I want to use clipper to get part of raster file that is inside polygon which is used as clipper.
Here is the clipper:
It should be a 10x10 km box.
Please take a look at min extents: 520000.0 , 6160000.0
And here is the clippee (raster file)
And now I'm very surprised with clipper output (inside):
I don't know why that .3 appeared at decimal place?
Do you know what am I doing wrong?
My expectation is that it should start with border of clipper which is exactly 6160000.0
nielsgerrits
Forum|alt.badge.img+54
What is the raster cell size? RasterPropertyExtractor --> _spacing_x / y
Forum|alt.badge.img+50
You're not doing anything wrong but when clipping rasters FME is returning whole pixels (which makes sense, otherwise clipping would involve resampling).
  • February 19, 2019
hello @nielsgerrits
it is both x/y 0.7
  • February 21, 2019
@redgeographics Thanks for the answer but I have a question here:
I used also other tool like presented here:
https://gis.stackexchange.com/questions/200407/merging-gdal-tiles-and-crop-via-bounding-box
gdalwarp command that I used is:
gdalwarp.exe -of GTiff -co COMPRESS=LZW -cutline clipper.kml -crop_to_cutline tiffFilesToBeClippedAndMerged.vrt result.t
and the gdal info for file generated this way is:
Origin = (540000.000000000116415,6170000.000000001862645)
Pixel Size = (0.699986000280060,-0.699986000280581)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  COMPRESSION=LZW
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  540000.0006170000.000) (  9d38' 9.67"E, 55d40'27.01"N)
Lower Left  (  540000.000, 6160000.000) (  9d38' 4.44"E, 55d35' 3.56"N)
Upper Right (  550000.000, 6170000.000) (  9d47'42.04"E, 55d40'23.68"N)
Lower Right (  550000.0006160000.000) (  9d47'35.50"E, 55d35' 0.23"N)
Center      (  545000.000, 6165000.000) (  9d42'52.91"E, 55d37'43.71"N)
while for raster processed with fme like I described above it is:
Origin = (540000.000039999955334,6169999.800039999186993)
Pixel Size = (0.700000000000000,-0.699951000979980)
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=LZW
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  540000.0006169999.800) (  9d38' 9.67"E, 55d40'27.01"N)
Lower Left  (  540000.000, 6160000.300) (  9d38' 4.44"E, 55d35' 3.57"N)
Upper Right (  550000.200, 6169999.800) (  9d47'42.05"E, 55d40'23.67"N)
Lower Right (  550000.2006160000.300) (  9d47'35.51"E, 55d35' 0.24"N)
Center      (  545000.100, 6165000.050) (  9d42'52.92"E, 55d37'43.72"N)
So I wonder what can I do in FME to have the same results as I have using GDAL?
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=LZW
  INTERLEAVE=PIXEL
Corner Coordinates:
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=LZW
  INTERLEAVE=PIXEL
Corner Coordinates:
From what I gathered gdalwarp not only clips but also resamples the image. You can comfirm this by checking the info on the original raster (specifically the pixel size).
Essentially there's 2 ways to handle clipping a raster that we're seeing here:
  1. The FME Way: take all original pixels that are fully inside the clip polygon and output those. Unless your clip polygon lines up exactly with the pixel edges the result will be a little bit smaller than the clip polygon.
  2. The GDAL way: take all original pixels that are fully or partially inside the clip polygon, then resample them so that the new pixels line up exactly with the clip polygon.
The benefit of the FME way is that every resulting pixel still matches with the original one. With the GDAL way I'm not so sure.
If you want FME to behave in the GDAL way you'll have to figure out the current pixel size and then resample the raster so that its new pixels line up perfectly with the clip polygon before clipping. To be honest, I can't really say how to do that right now :) (but I'm jetlagged)
  • March 2, 2021
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=LZW
  INTERLEAVE=PIXEL
Corner Coordinates:
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=LZW
  INTERLEAVE=PIXEL
Corner Coordinates:
same problem, would you have any resolution?
kailinatsafe
Forum|alt.badge.img+21
Hello @thanatej​ , thanks for your question. Generally, raster extents will always be > than vector extents because of the nature of the grid data structure. Could you tell me what are you trying to solve? I think the best approach is to resample first, then clip (as suggested above). I suppose you could attempt to rasterize the polygon to make a pixel mask, but depends on the context of your data! You might have come across this resource before, but I thought I'd include it anyways - goes through a lot of raster processes in FME: https://www.safe.com/blog/2014/07/raster-master/. Hope this helps, Kailin.
