clipping each clipper against the clippee
  • Nov 27, 2018 8:31 AM UTC
  • 100 views
boubcher
Forum|alt.badge.img+11
@takashi
I am looking to clip each clipper ( circle ) against the clippee ( polygon),
what I am getting from the transformer is 1 st the polygon will clip the first circle then the balance of the polygon will be clipped with the second circle
from the transformer we should get 2 inside and 2 outside features
Best answer by takashi
If I understood the requirement correctly, this workflow would be a solution.
  1. Add unique ID to the circles.
  2. Use the SpatialRelator to collect and store IDs of circles (Supplier) that are spatially related to the polygon (Requestor) into a list attribute which will be added to the polygon.
  3. Use the ListExploder to explode the polygon on the list. Here, each resulting polygon will have an ID of a related circle.
  4. Clip the polygons by the circles grouping by ID. Done.
Forum|alt.badge.img+54
  • Nov 27, 2018 8:38 AM UTC
The clippee is the feature to be clipped, if you want the output to be the areas of the circles inside the polygon and the areas outside the polygon, then the circles need to be your clippees and the polygon your clipper
  • Nov 27, 2018 1:13 PM UTC
boubcher
  • Nov 28, 2018 5:00 AM UTC
@takashi
Thanks ,
this what I was looking for
