Clipper - Attributes are not merged in Outside output
  • Feb 11, 2019 8:29 PM UTC
  • 117 views
Im using FME 2016, and i need to merge attribute of the clipper and the clippee on the outside clipper, i already checked the merge attributes checkbox , Is there any transformer can help me with that please?
erik_jan
Forum|alt.badge.img+26
  • Feb 11, 2019 8:39 PM UTC
If you have only one Clipper and need the attributes on the Outside port, I would use a FeatureMerger transformer after the Outside port, with the Supplier being the Clipper and join on 1 = 1 (always joining).
Use attributes only as a setting.
Hope this helps.
  • Feb 11, 2019 8:59 PM UTC
Hope this helps.
Thank you for your help, im very new on fme , can you explain me how the feature merger work ?
erik_jan
  • Feb 11, 2019 9:23 PM UTC
It should look like this:
The the Merged output port of the FeatureMerger will contain the Data with the attributes from the Clipper merged to it.
The join on 1 = 1 means that every data record will be joined with the Clipper record.
The attributes only means that the Clipper geometry will not be on the data.
If an attribute is on both the data and the clipper geometry, the data attribute will be used.
  • Feb 12, 2019 2:28 AM UTC
Thank you very much for your help its works
