Clip polygon by lines
  • August 26, 2021
  • 10 replies
  • 192 views
ienesaglam60
Forum|alt.badge.img+3
Ekran AlıntısıSelected blue area is polygon. Red lines is line.
I want to cut the blue area according to the lines and create 3 areas.
Best answer by gio
@ienesaglam60​
Hi, the same workbench but now with your sampe data.
Tolerances for snapping have been changed accordingly.
Workspace is attached.
Here is picture of result
PolygonClipping
danilo_fme
Forum|alt.badge.img+57
  • August 26, 2021
Hi @ienesaglam60​
Did you try use the transformer LineonAreaOverlayer?
Thanks in Advance,
Danilo
ienesaglam60
  • August 27, 2021
Yes i try but I can't get what I want.Thank you
gio
Forum|alt.badge.img+15
  • August 27, 2021
@ienesaglam60​
Coerce area to lines.
Snap your cutting lines to those (vertexsnapping in your example). Use polygon as anchor to keep polygon as is. (topologybuilder is also used for this as the later versions have tolerance)
Build area.
danilo_fme
  • August 27, 2021
Please, could you send us your data sample?
Thanks in Advance,
Danilo
gio
  • August 27, 2021
@ienesaglam60​
Hi here is an workbench
Using Topologybuileder or Interscetor.
Crucial is of course Snapping and snappingtypes. (depends on quality on the inputobjects. In my case i drew your examples in Inkscape so it was not topologicaly tight))
Grets.
gio
  • August 27, 2021
a pic
PolygonClipping
ienesaglam60
  • August 27, 2021
Thanks in Advance,
Danilo
attached sample dataset.
ienesaglam60
  • August 27, 2021
attached sample dataset.this ws I'm not sure if it's appropriate.
gio
  • August 27, 2021
@ienesaglam60​
PolygonClipping
ienesaglam60
  • August 27, 2021
This is awesome . Thank you so much.
