CKANConnector - Upload error HTTP 400: "Bad request - JSON Error: Invalid request. Please use POST method for your request
  • May 16, 2025 2:37 PM UTC
  • 99 views
jpbarnes
With the CKANConnector able to list Datasets and Resources without any issue, so I know CKAN Connection is good.   If I try to add and update a resource I receive the  “upload error HTTP 400: "Bad request - JSON Error: Invalid request. Please use POST method for your request”    I’m pulling the Dataset and Resource for the update resource from the dropdown.    Acts like a permission issue but I’m connecting as an Admin  on the openGov side.
hkingsbury
Forum|alt.badge.img+73
  • May 18, 2025 11:08 PM UTC
The error message suggests that you should be using a POST instead of a get.
Is this message coming directly from the CKANConnector? You may need to use an HTTPCaller to make the request instead
jpbarnes
  • May 19, 2025 2:49 PM UTC
When using FME workbench 2024.1 and I received this error.   I actually have 2023 on the same device so without making any changes.   I ran the workbench in 2023 and it was successful, the workspace was built in 2024.   really not wanting to go to the latest FME workbench since our server is still back on 2023.
