Checking if file GDB contains feature classes or a raster/mosaic dataset
  • Mar 21, 2022 1:09 PM UTC
  • 76 views
dms2
Forum|alt.badge.img+11
My FME translation includes 2 different streams depending on the type of data provided in a zipped file GDB. So the first step before processing data is to test whether it contains a rater dataset/mosaic dataset or any number of feature classes.
I don't want to read data yet, just check the data type of feature datasets.
What's the best way to check that? Tried a generic schema reader but it doesn't provide an attribute with the format of feature types inside the file GDB.
nielsgerrits
Forum|alt.badge.img+67
I would use a FeatureReader, set Features To Read to Schema Features.
2022-03-21_15h58_12
