Changing order of columns in "TableAdder"
  • Jun 21, 2017 9:23 AM UTC
  • 6 replies
  • 90 views
I'm using the custom transformer "TableAdder" to create a table. But the columns are placed alphabetically - left to right - but I want to change the way they are placed. How can I do that?
mark2atsafe
Forum|alt.badge.img+59
I'm taking a look at this transformer and will get back to you shortly. I think it also needs fixes for missing/null values, which weren't available when it was first implemented.
mark2atsafe
OK, I tried to make some updates, but there's some other issue that causes the text to just keep disappearing. Looks like the 'b' word! I've filed a report with our developers, but it does mean I can't really do much to update the transformer. At a glance I would say re-sort the data after the AttributeExploder_2 transformer. There is a Sorter there that might be setting the order, so check that too.
Hope that helps.
mark2atsafe
Hope that helps.
The dev team fixed the b*g that caused text to disappear (2017.1, build 17516) so I will install that when available and see if I can make the updates you need.
mark2atsafe
Hope that helps.
OK, so I have it working now, but I still don't think there is a good way to set the column order. The Select Attributes parameter doesn't let you pick the order. It's filed as PR#64217, but I don't see that one being fixed quite as quickly. So, for now, I have no way to resolve this one. Sorry.
  • Oct 29, 2019 3:58 PM UTC
Hope that helps.
Any update on this please? I also need to reorder the columns.
Thanks
gio
Forum|alt.badge.img+15
  • Oct 29, 2019 4:14 PM UTC
i posted a table builder not long ago.
One part that the user set a sorting order on any column.
The sorting order is entered prior to tablebuilding. Either manualy like a mapper, or by providing a sort map (txt,csv etc.)
Hav'nt seen any reactions to it though. Maybe i should not have named it "Tabel messing ... again" ?
Here is one where the column order is added trough a attributecreator.
Tabel messing ... again.fmwt
