ChangeDetector Update slow to write
  • Feb 14, 2024 3:10 PM UTC
  • 290 views
silverj
Forum|alt.badge.img+3
Hello,
We have been troubleshooting this FME translation for a while and can’t figure out a solution.  The Inserted, Deleted features of the ChangeDetector write reasonably quickly but the Update features are writing so slow it will be unusable, GIF for reference.
Things we’ve tried without any differences:
Indexing all fields in ArcCatalog
Indexing Just the Match Column fields (3 Fields to make a Unique ID)
Indexing and using a CRCCalculator field for the Match Columns
Adding a FeatureHolder after the ChangeDetector
Adding a AttributeManager after the ChangeDetector removing unused fields
Writing to a File Geodatabase (SDE is ultimately the goal and being used in the gif below)
Not Checking the Geometry in the ChangeDetector
Changing Transaction types in the Writer
Changing and testing various other settings in the transformers and writers
Thank you for any suggestions!!
Best answer by nielsgerrits
To be honest, this is hard to debug via a forum. But my gut feeling is it has to do with the 3 fields to match. I would try and test if using one field, OBJECTID, only and see if performance is OK. When this is the case, merge OBJECTID to the feature in workbench. This is how I do it in my workspaces on SDE.
What FME version do you use?
nielsgerrits
Forum|alt.badge.img+67
  • Feb 14, 2024 4:02 PM UTC
hkingsbury
Forum|alt.badge.img+73
  • Feb 14, 2024 9:25 PM UTC
I’m pretty confident it’s SDE slowing down the process. Updates are generally pretty slow in SDE land, I’m also guessing you’re probably using a versioned feature class? - to be clear if this is the case, the issue lies with SDE/Esri, not FME
One way to confirm its the updating is to add a feature holder between the change detector and the writer. If all features pass through the change detector then slowly filter out of the feature holder then it confirms SDE is slowing it down
burgasser
Forum|alt.badge.img+5
  • Feb 14, 2024 9:59 PM UTC
Is there anyway to use a single field as the unique identifier?  Also, be aware of the following for the CRCCalculator:
“Like all popular CRC algorithms, different features could produce the same CRC value with minimal probability.”
silverj
  • Feb 20, 2024 7:23 PM UTC
So using OID isn't an option for our use case but using it as a test did help us get on the right path.  The problem was that our match columns weren't producing Unique rows as we had thought.  We were able to add another column to the Match Columns (Now 4 total fields that we are checking instead of the 3 I mentioned in my post) that would provide unique rows and everything ran correctly.  Thank you for your help!
