Change the field type from string to integer for all field automatically in writers
  • Feb 18, 2019 10:15 AM UTC
  • 5 replies
  • 331 views
Hi ,
I am wondering if there is a way to change the field type change the field type from string to integer for all field in writers in one go.
Like the screenshot below I manually changed the field type but sometimes I have a huge number of fields and need to have them in Int instead of string, Is this possible?
Cheers,
Rawan
Best answer by ebygomm
You can select all and then change the type and that will change everything
Forum|alt.badge.img+54
  • Feb 18, 2019 10:44 AM UTC
nielsgerrits
Forum|alt.badge.img+67
Learned something new today :)
  • Feb 18, 2019 10:59 AM UTC
Combined with the filter, it's then straightforward to bulk update attribute types. All that's missing is a select all button
  • Feb 18, 2019 10:57 PM UTC
Thanks it works fine !
Forum|alt.badge.img+63
Me too, I did not know that :)
