Change/Rebuild polygon defining start point/vertex based on Z value
  • Jul 21, 2021 3:11 PM UTC
  • 147 views
od10
Forum|alt.badge.img+4
Hello,
I need to rebuild polygons from points, but need certain vertices' criteria.
  1. Polygons need to be digitised in a clockwise direction (can use orientor transformer for this)
  2. Polygons need to start with a vertices which has highest z value.
How do i define the start vertice for the polygon when rebuilding the polygon?
Capture
Thanks
@Takashi Iijima​ @david_r​ @Hans van der Maarel​ @ebygomm​
jdh
Forum|alt.badge.img+41
  • Jul 22, 2021 9:50 PM UTC
I haven't tried this at all, but what if you:
connected the vertices into a line (polygon perimeter)
used a coordinateExtractor to get the list of vertices , sorted the list so the highest z was first
vertexCreator from the coordinates of the first element in the list
pointOnLineOverlayer to split the the line at that point
rebuilt the resulting two lines into a polygon. (an areaBuilder might pick them up in the correct order anyhow, if not then using a LineCombiner after you switch the order of the lines would work)
DanAtSafe
Forum|alt.badge.img+23
  • Jul 23, 2021 1:35 AM UTC
Hi @od10​ Here's a workspace showing @jdh​ 's idea. The tricky part is hoping that the 2 lines will be in the right order to make the vertex with the highest Z value the start/end point of the polygon. I found that the TopologyBuilder did this consistently.
