Change mapinfo workspace layer filepaths
  • November 6, 2014
  • 72 views
alison
Participant
We have about 100 mapinfo workspaces for a project
We have moved offices and our drive letter mapping is going to change
This will mess up all the workspaces
Is there a way FME can edit the workspace (it can be viewed as text in notepad) to change the drive letters, similar to how you can use the string replacer in tab and excel files
This would also be useful for if you moved mapinfo layers to a new location rahter than having to re-add them all to workspaces
  • November 6, 2014
you could try using the Text Line reader and writer with a StringReplacer in the middle.
David
alison
Participant
  • Participant
  • November 6, 2014
Thank you, I will give it a try
gio
Forum|alt.badge.img+15
  • November 6, 2014
You could use search and replace in notepad as well of course...
Though using the stringsearcher is more powerfull.
Using a AttributeCreator & Co. with tcl functions is even more powerfull.
