Change detector attribute no matching problem
  • August 8, 2017
  • 27 replies
  • 327 views
Show first post
arxit
Forum|alt.badge.img+5
  • August 9, 2017
The AttributeTrimmer suggested yesterday would've fixed your problem.
Yes, it works. I didn't try it yesterday (i had seen only suggestion about StringFormatter, sorry)
Forum|alt.badge.img+53
  • August 9, 2017
Hello @arxit,
Are you able to attach your workspace or a sample of the data(1feature from each source to an FFS file would work)?
Secondly, on one of the images, 'pict-1.png' it almost appears that there is whitespace at the end of the value so rather than '1391' it looks like it could be '1391 '. Are you able to just verify this? I think I may just be seeing things/stretching it.
I guess the next question is should the featuremerger merge when one attribute has a trailing space and one doesn't....
