cant enter newline in filewriter
gio
Forum|alt.badge.img+15
I seem not able to enter a newline at the end of a string whilst using attributefilwriter in append mode.
I use a attributecreator, i can even pick the newline symbol, but still everything is one long string without newlines. (2013 sp2)
Windows preview shows it correct but when i open it its not.
Is it even possible the way im using the filewriter?
( entering \\ln or LN does not work either)
...aaah if i write it to .csv rather then .txt it works...
tx for reading... ;)
Best answer by takashi
Hi Gio, try inserting a CR (Carriage Return) before each Newline.
Takashi
  • June 24, 2014
Takashi
I have built up a dynamic string like below
129321293220190814120724.9908436"->"File2 $(LN)":"920190814120725.1245068"->"File1$(LN)":"1293212932129321293212932
everytime this goes into the file, it should go in as a new line in places where $(LN) is specified
how is it done?
how is it done?
I have tried
1. Replacing $(LN) with $(CR)
2. In the FME editor, pressing "enter Key" for a new line
When I open the text file, it always shown in a single line
I use an attributeFileWriter
I know the answer is in the "Target File Encoding" but which one?
