cannot run workspace in FME Caller Widget
  • Jan 8, 2020 7:39 AM UTC
  • 36 views
terezia86
we did install the FME Caller Widget into our Webserver Portal to run the workspaces from FME Server there.
Unfortunately we were not able to run them due to: "You don't have permission to access this workspace."
We checked all permissions, repositories where are the workspaces and it seem to be everything fine. Also user names and passwords.
when we create an Server App from the same workspace, we can successfully run it in our Portal.
Anybody any idea? Are there maybe other things to think about?
Thanks a lot
Forum|alt.badge.img+63
It could be related to the CORS settings, you'll find those in the FME Server user interface under Admin -> System Configuration -> Networking
The FME Caller Widget is a 3rd party add-on, I would also recommend you check with the support staff at the developers.
