Can the output of an attribute file writer transformer be combined with the "zipped" output of a text file writer?
  • Dec 9, 2019 4:42 PM UTC
  • 82 views
bellrosemike
If I zip the output of the attribute file writer (example: c:\\test.zip\\photo.jpg) and then use a fanout expression on my text file writer to send the data to the same test.zip file.... Only the text file will be present in the output. However, if I write them to (2) separate zip files the process works. However, I need my output in the same zip file. Does anyone have thoughts why it does not work when they point to the same output file?
erik_jan
Forum|alt.badge.img+26
  • Dec 9, 2019 5:20 PM UTC
I tested it and got the same result.
I did find a work around, using a SystemCaller:
Hope this helps.
bellrosemike
  • Dec 11, 2019 2:21 PM UTC
That is an interesting work around... Thank you very much for your response. I have never used SystemCaller before, but that could open a wide range of possibilities when deploying the solution to server.
