Can the FME PythonCreator generate a csv in memory and output it embedded in an attribute on the feature?
  • Jun 14, 2022 3:34 PM UTC
  • 253 views
andrew_r
Forum|alt.badge.img+4
I'm trying to migrate some python into FME that involves DataFrames as the end result.  Rather than trying to manually handle converting the DataFrame to attributes, I thought I could convert the dataframe to a csv in python memory first,  output it as a file on the feature, and then use a CSV reader in the workspace to parse the file.  I ran into issues with getting the csv out to an attribute, so if anyone knows of a way to do this I'd appreciate it.
Below is a simplified version of my code (it involves Esri's ArcGIS API for Python), and then I'm using io.StringIO to handle the csv in memory, but I've never used that function before.
When I run the workspace with this as a Python Creator, i get the error:
Python Exception <TypeError>: Could not convert attribute value to a supported attribute type.
Traceback (most recent call last):
 File "<string>", line 33, in input
import fme
import fmeobjects
import csv
import io
from arcgis.gis import GIS
import pandas as pd
gis = GIS('https://arcgis.com')
class FeatureProcessor(object):
    """Template Class Interface:
    When using this class, make sure its name is set as the value of the 'Class
    to Process Features' transformer parameter.
    def __init__(self):
        """Base constructor for class members."""
        pass
    def input(self, feature):
        #Search, return data and convert to dataframe
        content = gis.content.search(query="transportation",max_items=10)
        df = pd.DataFrame(content)
        #Convert dataframe to CSV "In python memory"
        s_buf = io.StringIO()
        df.to_csv(s_buf)
        s_buf.seek(0)
        #Attach the csv in memory to the FME feature as a new attribute
        feature.setAttribute('users_csv_file',s_buf)
        self.pyoutput(feature)
    def close(self):
        """This method is called once all the FME Features have been processed
        from input().
        pass
    def process_group(self):
        """When 'Group By' attribute(s) are specified, this method is called
        once all the FME Features in a current group have been sent to input().
        FME Features sent to input() should generally be cached for group-by
        processing in this method when knowledge of all Features is required.
        The resulting Feature(s) from the group-by processing should be emitted
        through self.pyoutput().
        FME will continue calling input() a number of times followed
        by process_group() for each 'Group By' attribute, so this
        implementation should reset any class members for the next group.
        pass
  • Jun 16, 2022 8:41 AM UTC
The method setAttribute() does not support StringIO objects, you'll have to explicitly cast s_buf to a str first, e.g.
feature.setAttribute('users_csv_file', s_buf.getvalue())
 See also https://docs.python.org/3/library/io.html#io.StringIO.getvalue
kailinatsafe
Forum|alt.badge.img+24
If @david_r​'s suggestion doesn't quite work, you could also try this variation:
feature.setAttribute('users_csv_file',s_buf.read())
You could also consider writing the CSV to a temp file on disk, set the attribute value to the name of the temp file, and use a FeatureReader to read the CSV temp file (opposed to outputting it as a file on the feature). Good luck! Best, Kailin.
