Can't read non-UTF8 json file
  • Apr 21, 2020 4:34 PM UTC
  • 9 replies
  • 139 views
fikusas
Forum|alt.badge.img+5
I'm trying to read in JSON file. It has ANSI encoding. The reader throws an error:
"A JSON syntax error was found at line 1, column 49. A sequence of bytes was found which is invalid in the UTF-8 encoding."
Is it possible to get around this?
jdh
Forum|alt.badge.img+41
  • Apr 21, 2020 4:38 PM UTC
You can read the JSON with a text file reader, which has a parameter to specify the encoding, and then use the various JSON transformers to turn the text string into features with attributes.
fikusas
  • Apr 22, 2020 5:55 AM UTC
How can this be splitted into separate attributes when read in with text reader?
      "objektokodas" : 50002363,
      "pavadinimas" : "7-2, 7-5, 7-6, 7-7, 7-8, unikalus numeris 1094-0073-0016:0031, plotas 65,35 kv. m, pusr?syje",
      "adresas" : "V. Sopeno g. 12, Vilnius",
      "teritorija" : "Vilnius",
      "weblink" : "https://www.turtas.lt/8952",
      "aukcionas" : {
         "skelbimoPavadinimas" : "Negyvenamosios patalpos",
         "arElektroninisAukcionas" : true,
         "objektoPradineKaina" : 155700,
         "zemesPradineKaina" : null,
         "sklypasNuomojamas" : false,
         "aukcionoData" : "2019-12-09T09:00:00",
         "registracijosPradzia" : "2019-12-02T00:00:00",
         "registracijosPabaiga" : "2019-12-04T23:59:00",
         "weblink" : null
      "statiniai" : []
itay
Forum|alt.badge.img+19
  • Apr 22, 2020 6:31 AM UTC
      "aukcionas" : {
         "weblink" : null
      "statiniai" : []
Hi @fikusas,
As mentioned by @jdh, you can use JSOn transformers to extract the data.
When reading the JSON as text make sure you are reading the whole file as one attribute value:
Hope this helps.
fikusas
  • Apr 22, 2020 6:47 AM UTC
Hi @fikusas,
Hope this helps.
Flattener gives me this:
and ListExploder ends up with this:
What I'm doing wrong?
itay
  • Apr 22, 2020 7:00 AM UTC
and if you inspect the results from the ListExploder in de feature information window?
fikusas
  • Apr 22, 2020 7:02 AM UTC
I see this:
itay
  • Apr 22, 2020 7:09 AM UTC
I see this:
looks good to me...
fikusas
  • Apr 22, 2020 7:10 AM UTC
looks good to me...
AtributeExposer did the trick. Now I can see attributes in Visual Preview. Thanks!
itay
  • Apr 22, 2020 7:14 AM UTC
glad I could help
