Can't create FileGeodatabase with FME Desktop over network
  • Aug 19, 2019 7:33 PM UTC
  • 7 replies
  • 192 views
I have a workbench that Inputs a fileGDB that has a feature class with just a few points. The output location is generated based on the input with a timestamp added. Savings as a new file gdb (Regular API and the open API) ones both work when saving to local C drive but not anywhere on the network and gives the following error:
"Unable to connect to the File Geodatabase at 'H:\\Temp\\CAD_Test.gdb'. Make sure the correct filename was specified, and that the geodatabase wasn't saved with a newer version of ArcGIS than the one installed locally. The error number from ArcObjects is: '-2147024894'. The error message from ArcObjects is: {}"
Using UNC paths is same result
If I change the file type to .csv I can export over the network no problem, but filegdb fails and don't know why, have the drop table setting set to yes
Any ideas?
Best answer by tforward
After much trial and error and tweaking, I was able to get it working:
  • Feature Writer (FGB Open API Only works)
  • Set table handling to "Drop and Create"
  • Set the Template File Geodatabase to "fme_dataset" (This is the input fileGDB)
  • For any attributes you need to use the attribute exposer to bring them over (Don't bring over objectID, it will get created automatically) [I'm trying to figure how to do this dynamically but not sure at moment]
  • Works with UNC paths
  • FME will report that 0 features are written but if you go look at the data it's there.
Do not use the FGB ESRI API it does not work
Forum|alt.badge.img+63
Are you overwriting an existing FGDB on the network? I have the same issue and usually work around it by deleting the original before running the workspace but it'd be nice if there's a more stable solution.
  • Aug 20, 2019 9:42 AM UTC
No, newly created file geodatabase.
mygis
Forum|alt.badge.img+14
  • Aug 20, 2019 10:05 AM UTC
1. Do you have full access on that drive?
2. Are ArcGIS and FME compatible? Please check out this article: https://knowledge.safe.com/articles/1517/notes-on-fme-and-esri-versions-and-compatibility.html
3. Does the same error occur on that drive when the format is "Geodatabase API"?
  • Aug 20, 2019 10:34 AM UTC
I'm not sure I understand. When you say driver to you mean drive? If so, than yes I do have write access to that drive (also tested with exporting new .csv and that works). However, If I save a new file geodatabase to local C drive it works, over the network it does. Yes, is compatible and again it works when exporting to C drive so confirms it. Yes both the regular Api and the open api for filegeodatabase have the same error. My current hacky workaround is to write to the C drive then move it to the correct location after it is created...
mygis
  • Aug 20, 2019 11:40 AM UTC
is anyone else opening the geodatabase?
Can you drop the tables before writing?
Other possibility, I have read before, is there an antivirus on both machines? Can you disable them and test?
These threads are worth checking out as well.
https://knowledge.safe.com/questions/84633/file-geodatabase-output-in-network-location-issue.html
there is a similar thread here. https://knowledge.safe.com/questions/46141/overwriting-existing-file-geodatabase.html
Can you please share your workspace?
p.s. thanks for pointing out the typo, it has been corrected.
  • Aug 20, 2019 11:42 AM UTC
  • Aug 20, 2019 11:43 AM UTC
I got it working see above
