Can PythonCaller determine which transformer/source a feature is from?
  • Aug 1, 2016 2:20 PM UTC
  • 73 views
I have several (SQLCreator) sources and other transformers all feeding into a PythonCaller. I'm using the PythonCaller to pull certain attributes from each feature and create new features.
Is there a good way to determine which features come from which sources/transformers inside the Python script?
Currently I'm testing each feature for specific attributes, but this will not work for situations where features from multiple sources have the same attributes.
jdh
Forum|alt.badge.img+41
  • Aug 1, 2016 2:33 PM UTC
I create a specific attribute, that explicitly contains what "stream" the data is coming from.
There is an attributeCreator on each stream just prior to the PythonCaller, with a common attribute (I use _!type) with a different value for each stream. I retrieve that value in the PythonCaller and test for the various values.
Likewise if I want to split the output, I attach a temporary attribute to the outgoing feature and use a tester/testfilter after the PythonCaller.
  • Aug 1, 2016 6:52 PM UTC
Hello @carlreedw
For these transformers:
The following python code will display:
Creator_CREATED
Creator_2_CREATED
import fme
import fmeobjects
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self,feature):
        print str(feature.getFeatureType())
        self.pyoutput(feature)
    def close(self):
        pass
Regards,
Larry
