Can MapTextLabeller directly work on AutoCAD DWG file ?
  • Mar 21, 2019 6:52 AM UTC
  • 39 views
I need to work on label/text placements in an AutoCAD DWG file. I am exploring MapTextLabeller transformer for this. Have anyone explored this option ?
Thanks
bey_atkins2009
xiaomengatsafe
Forum|alt.badge.img+11
Hi @bey_atkins2009, I'm quite certain MapTextLabeller is able to help with label/text placement in DWG files. The MapTextLabeller is an extra cost 3rd party plugin. This page contains some general info about the plug in, including links to apply for a free trial licenses for the plugin at the bottom. This article has some great examples on how to use the transformer, which might be helpful once you have access to it.
Hope this helps. Cheers,
Xiaomeng
