can i split 3d entity in skp (sketchup) file?
  • Jun 6, 2018 2:41 PM UTC
  • 39 views
i build a 3d buildings scene in sketchup, when i convert it to 3d tiles, i found there is only one feature in b3dm, i can't divide different buildings each other, can i split 3d entity in skp file ? or any good solution to solove it ?
thanks!
daveatsafe
Forum|alt.badge.img+24
  • Jun 7, 2018 5:10 PM UTC
Hi @chiangbt,
A Sketchup file is read in as a single aggregate feature. You can use the Deaggregator transformer to break it up before writing to b3dm.
