Can FME read a geodatabase as a zip file?
  • Apr 15, 2016 3:02 PM UTC
  • 5 replies
  • 246 views
I can't find information about I could do the above i.e. getting an FME reader to read an ESRI geodatabase as a zip file? My issue is that I want users to submit those geodatabases that I then want to validate the attributes before doing anything else..
  • Apr 15, 2016 3:08 PM UTC
Hi
Sure, no problem. Just point the reader to the zip file rather than the gdb directory. Nothing else needed.
David
  • Apr 15, 2016 4:05 PM UTC
As David said - but what version of FME are you using? I think it was added in FME 2015.0 as I just tried FME 2014 and it isn't an option (using Esri Geodatabase (File Geodb API) reader)
  • Apr 27, 2016 9:32 PM UTC
@aj7 just to add I have been trying to read a large GDB zipped by Windows built in compression functionality and it won't read it with FME 2016. The same GDB compressed with 7Zip is readable. Problem logged with Safe support team.
darkspatiallord
Forum|alt.badge.img+8
We tried doing this by having the zip on s3 and reading directly with FileGDB reader and it doesnt work.
mark2atsafe
Forum|alt.badge.img+59
Thanks. I think it should work for sure - and I don't use 7Zip - so it's good to hear you logged a case with the support team so we can look at it properly.
