Can FME convert Ground coordinates to UTM?
  • Feb 12, 2020 10:48 PM UTC
  • 174 views
I have an AutoCAD drawing in ground coordinates and need to get this into a usable projection to use in ArcGIS Pro. Is FME able to do this? I have the math that is typically used to do such a conversion (below), but I am not quite clear how to implement this in an FME workspace:
To Transform Ground to UTM Coordinates
Example: Point100 (Ground) 13262.582 m N, 4380.119 m E
1. Shift back to the original scaled coordinate value:
13262.582 m + 6,000,000 m = 6013262.582 m N
4380.119 m + 410,000m = 414380.119 m E
2. Scale Point 100 from the Ground down to the Grid using the CSF:
6013262.582 m * 0.9996899303 = 6011398.051 m
414380.119 m * 0.9996899303 = 414251.632 m
Suggestions?
Thank you.
@prpa_gis Affiner tranformer or a combination of the Offsetter and Scaler should do the trick. Then the CoordinateSystemSetter to set the coordinate system.
  • Feb 13, 2020 12:38 AM UTC
Thanks Mark:
I will give this a try. This is exactly the software one would think would be perfect for this type of transformation, and this tool would be great if I can get it to work. Now I have a project :-). I'm assuming that it's going to be something like Reader ->Affiner transformer->projector->writer?
  • Feb 13, 2020 9:50 PM UTC
Naturally I'm having all sorts of problems with this. What my brain interprets as "intuitive" and what FME is asking me to do are obviously two different things :-).
This is what I have managed to create...all I'm trying to do is get something (anything) to transform, and once I have achieved that I can make the FMW more elaborate:
I get a fatal error starting with "Cannot write a non-area feature to an area feature class". However, I was trying to select and set the conversion to using a linear layer and output to a line type, but I continue to get the similar error messages.
I did get it to run without errors once, but there was no output at all.
My Affiner looks like:
My Reprojector looks like this (I thought setting the source coordinate system to the source ACAD file was a safe bet, but perhaps not?
In any case, I'm obviously missing something, but I'm just spinning my wheels here at the moment.
Suggestions?
daveatsafe
Forum|alt.badge.img+24
  • Feb 18, 2020 9:07 PM UTC
Hi @prpa_gis,
To implement the transformation you described, please use an Offsetter, then a Scaler, in order to retain the order of operation.
Set the X offset to 410000 and the Y offset to 6000000.
Set both the X and Y scale to 0.9996899303.
Next, use a CoordinateSystemSetter transformer to set the coordinate system to the applicable UTM zone and datum (ie. UTM84-10N).
