Can FME 2014 64bit could be slower than FME 2013 32bit?
  • January 22, 2014
  • 44 views
I just have installed FME 2014 64bit, and I think that translations are significantly slower than with my previous FME version (FME 2013 32bit).
Am I the only one to notice that? Should I re-install FME 2013 32bit to compare time of running for both versions?
  • January 22, 2014
I am on Windows 7 b4bit, 8gb RAM
fmelizard
Forum|alt.badge.img+22
Hi Burton,
We would certainly like to look into your issues further.  I suggest you contact support@safe.com to file a support case with details of your configurations and the translations (workspaces and logs are great if you can provide them).  So that we can get to the bottom of what may be causing your slowdown.
Cheers,
Iris
