camelCase Attribute renamer
  • Feb 8, 2026 11:18 PM UTC
  • 144 views
nepalikiwi
Forum|alt.badge.img+4
I wanted to make all my attribute to camelCase, currently they are separated by underscore.
I wanted to change my attribute name to camelCase, so using regular expression in BulkAttributeRenamer transformer to find text following underscore using regular expression replace: _([a-z])
However, i am not sure what String parameter i have to put to make the selected character Capital letter. I have tried \U\1 and also few other but its not working. Basically wanting to find String parameter value?
Forum|alt.badge.img+54
  • Feb 9, 2026 8:49 AM UTC
I’m not sure if you can modify the matched group in any way.
Hacky workaround would be to add a prefix, change to title case and remove a prefix (assuming attributes don’t start with an underscore
hkingsbury
Forum|alt.badge.img+73
  • Feb 11, 2026 6:28 PM UTC
I think that’s going to be the best way. You could use Python but that would then require dynamic schemas and would add a whole extra level of complexity
